libblender_cpu_check.so: No such file or directory
nach download von blender 4.2.5 bekomme ich diese Fehlermeldung:
nach Eingabe von lddtree erscheint die komplette Liste :
lddtree ./blender
./blender (interpreter => /lib64/ld-linux-x86-64.so.2)
    libblender_cpu_check.so => None
    libtbb.so.2 => None
    libutil.so.1 => /lib/x86_64-linux-gnu/libutil.so.1
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6
    libosdGPU.so.3.6.0 => None
    libosdCPU.so.3.6.0 => None
    libX11.so.6 => /lib/x86_64-linux-gnu/libX11.so.6
        libxcb.so.1 => /lib/x86_64-linux-gnu/libxcb.so.1
            libXau.so.6 => /lib/x86_64-linux-gnu/libXau.so.6
            libXdmcp.so.6 => /lib/x86_64-linux-gnu/libXdmcp.so.6
                libbsd.so.0 => /lib/x86_64-linux-gnu/libbsd.so.0
                    libmd.so.0 => /lib/x86_64-linux-gnu/libmd.so.0
    libXrender.so.1 => /lib/x86_64-linux-gnu/libXrender.so.1
    libXxf86vm.so.1 => /lib/x86_64-linux-gnu/libXxf86vm.so.1
        libXext.so.6 => /lib/x86_64-linux-gnu/libXext.so.6
    libXfixes.so.3 => /lib/x86_64-linux-gnu/libXfixes.so.3
    libXi.so.6 => /lib/x86_64-linux-gnu/libXi.so.6
    libxkbcommon.so.0 => /lib/x86_64-linux-gnu/libxkbcommon.so.0
    libembree4.so.4 => None
    libcycles_kernel_oneapi_aot.so => None
    libsycl.so.7 => None
    libOpenImageIO.so.2.5 => None
    libOpenImageIO_Util.so.2.5 => None
    liboslcomp.so.1.13 => None
    liboslexec.so.1.13 => None
    liboslquery.so.1.13 => None
    liboslnoise.so.1.13 => None
    libOpenColorIO.so.2.3 => None
    libboost_python311.so.1.82.0 => None
    libOpenImageDenoise.so.2 => None
    libMaterialXFormat.so.1 => None
    libMaterialXCore.so.1 => None
    libusd_ms.so => None
    libopenvdb.so.11.0 => None
    libIex.so.31 => None
    libOpenEXR.so.31 => None
    libOpenEXRCore.so.31 => None
    libIlmThread.so.31 => None
    libImath.so.30 => None
    libboost_filesystem.so.1.82.0 => None
    libboost_regex.so.1.82.0 => None
    libboost_thread.so.1.82.0 => None
    libboost_date_time.so.1.82.0 => None
    libboost_wave.so.1.82.0 => None
    libboost_locale.so.1.82.0 => None
    libboost_iostreams.so.1.82.0 => None
    libboost_system.so.1.82.0 => None
    libboost_chrono.so.1.82.0 => None
    libboost_atomic.so.1.82.0 => None
    libboost_serialization.so.1.82.0 => None
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1
    libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6
    ld-linux-x86-64.so.2 => /lib64/ld-linux-x86-64.so.2
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1
OS: 6.1.0-28-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.119-1 (2024-11-22) x86_64 GNU/Linux
meine Hardware :
description: Motherboard
product: M5A99X EVO
Prozessor: AMD six core
RAM : 16 GB
Video-Card: Baffin [Radeon RX 550 640SP / RX 560/560X]
JMB362 SATA Controller
USB: 2 and 3
CMI8738/CMI8768 PCI Audio
Für eure Hilfe danke ich schon im Voraus
Viele Grüße
Willkommen im BlenderforumLächeln
Alle Treiber, Kernel etc. sind auf dem neuesten Stand?
Ansonsten als Erstes würde ich probieren, die Blender-Konfiguration mal zu löschen. Die sollte sich unter /home/.config/blender befinden. Wenn das auch nicht geht, würde ich mal eine andere Blender-Version testen. Die musst du dann halt entweder von der Webseite herunterladen oder als Flatpak installieren.
Das wären zumindest mal die Sachen, die ich als Erstes probieren würde.
Bei dir fehlen die Abhängikeiten (Dependencies) die eigentlich mit Blender im "./lib" Verzeichnis vorhanden sind. Wie hast du Blender installiert, wie startest du Blender und ist "./lib" vorhanden?
