"track to" constraint
Hello Loves,
i wanna track my camera to an object with "track to" constraint... this works perfectly... but the object is always in the middle of the camera,, i just want to adjust my object, so that it is a bit to the right but the camera still tracking.
hope you can help :****
Hi,
the simplest solution is: add an empty at the position the camera should look at and let the camera track the empty. Maybe you have to parent the empty to object or vice versa - I don't know what you want to do. If you want something like a TPS-cam, the empty should be the child.
regards
