Blender 4.2.0 python brush modifier
Under Blender version 4.0.2 I use following command in python and it works fine:
bpy.data.brushes["Draw"].strength = 0.26087  (just simplified example)
It does not seem to work the same on 4.2.0.
I can assign the value and can see it afterwards (so it has assigned it) but it would not change the value on the UI (the UI seems to use a value from somewhere else)
What do I need to know to get the correct modifier value changed for the brush for 4.2.0?
Many thanks in advance for your help.
Punky
