face selection
Dear experts,
I have a biscuit cutter with the motif of a guitar.
To make the cut edge a little thicker, I would have to select all the outer sides of the cut edge and extrude the surface along the normal one.
Sometimes there are motifs that have such narrow areas in the object that they can hardly be marked. Is there a way to select all areas of the cut edge with a single stroke?
I use the shortcut ‘L’ to select the entire cut-out edge, but I only want to select the cut-out edge. (As already started in the picture)
Thank you in advance.
